Temps for 8800GTX
26 Oct 2006
Cambridge UK
What sort of temps should i be looking at for 2x 8800GTx cards on a
(Idle and full out)
At the moment ive had my pc on all day today (7 hours+) and the temps are being displayed as 74c and 69c (using everest home edition) the metal plate at the back it quite hot however ive not been doing anything on it to stress the cards out (mainly file transfers from my old machine) im worried that when i try and actaully take the cards to a higher level that they will overheat.
What sort of temp level should i be looking at when im flogging them full out and are the levels i have at the momment worring :(
Check the air ventilation in your case. Try to get ATi tool and log the temp while playing games such as COH to see what load temps you're getting.
