Temps for Celeron G530
Below 70-75cc ideally.
But it will depend on your case airflow ect, what are your current temps?
Ok so if my mb has any temp monitoring or if I use Core Temp program, do they give actual core temps? And I need to be looking to keep it under 70-75c?
Thanks for the help.
Im currently running an Athlon X2 in the case and its idling at 32 and 38 on its cores, do Intels run cooler?
