- 7 Sep 2020
Rig:
CPU: i5-9600K
mobo: Asus Z390 Aorus Pro
mem: 2x8GB Ripjaws V 3000/14
GPU: Colorful iGame GeForce GTX 1070Ti Vulcan U Top
system disk: PNY CS3030
other: SB Titanium PCIE
case: Phanteks Enthoo Pro
Power supply:
PSU: Corsair RM750W (yellow label, gold-rated, 61A on 12V)
Mobo has an additional 4-pin EPS socket, which I can optionally plug into 6-pin PCIE through an adapter. PSU only has 2x(8+6) PCIE and 1x8-pin EPS, so I plug both PCIE 8s into the GPU (it's 8+8, instead of the usual 8+6 for a 1070ti), which means one of the cables has plugs going into both CPU and GPU.
CPU rarely gets to 170W as per HWMonitor.
Cooling:
CPU: TC14PE with 2xP14 on the sides (CPU_OPT) and SW3HS 14 centre (CPU), Cryonaut (dotted x method)
GPU: Accelero Xtreme III (no fan mod but thinking about it)
Air intake: 2xP14 front, 1xP14 bottom
Air exhaust: 1xSW3HS 14 rear, 1xPhanteks 14-something top
Current OC:
CPU: 4.7 @ 1.4 (showing 1.392 most of the time) but with boost enabled and its multiplier changed by +3 ('CPU Upgrade: Advanced' in mobo settings)
RAM: 1.4 just to be sure (1.35 XMP)
GPU: 2100/9100, PL 120%, voltage +53%
BIOS settings: disabled all C-States, VTd, etc., and everything else the official Aorus OC manual says should be disabled. LLC maxed out ('Ultra Extreme' or something like that) just in case.
Last TimeSpy score: overall 7475, CPU 6480, GPU 7684
Valley: 4500-ish @ 1440p ultra, AAx2 (from 3900-ish stock)
Temps aren't really the problem. I've seen up to about 92C on 5.1 attempts in Prime95 small FFT (passed but yielded lower TimeSpy scores than more modest OCs). I rarely hear the fans, even in benchmarks, forget in games. Running the fans at 100% doesn't actually change much compared to my silence-friendly custom curve.
Overdoing the OC simply results in failed benchmarks and bluescreens without temp issues. For example even when the GPU fails Valley, its temp doesn't exceed 65C. When the CPU fails Prime95, it's usually one of the cores crapping out immediately. Increasing the voltage by a large margin tends to help, but the results are disappointing (see above — lower benchmark scores than with a more modest OC) and the price too high. Even when I'm seeing 92C, the CPU doesn't approach 200W, so it's far below the cooler's probable TDP rating, whatever that would be. It feels like hitting the dies' limits, though I'm skeptical about there not being anything else one could do to squeeze out some more.
One curious thing I've noticed is that increasing the OC on the CPU tends to improve CPU benchmark results but harm GPU benchmark results. So… insufficient 12V line? Bus problems?
The 4.7 CPU clock with XMP on and boost enabled (with multiplier increased by a further 3) produces the best score of all combinations I could come up with (including higher stable CPU OCs with XMP disabled or 4.7 with no boost).
The GPU voltage setting doesn't do much, but it does increase Valley scores marginally up to a point, failing if too high (like 100% will fail where 100% passes) or too low (higher OCs seem to require more voltage to avoid crapping out, or alternatively they produce lower scores).
I'm not sure if the 65C temp point does something to the card, though I've never seen Valley exceed 64C, so perhaps there's a hint. However, the card had exceeded 70C on its factory cooler without crapping out.
Is there anything I could try? Perhaps some of those completely arcane detailed power settings on the last tier of the Aorus's advanced tabs? (Internal VR-something, yadda yadda.) Or something simpler that I may be missing? Or is the PSU my bottleneck? Or have I truly hit the dies' limits?
CPU: i5-9600K
Power supply:
Cooling:
Current OC:
