- 20 Jul 2007
- gloucestershire
hi just overclocked my e6850 to 3.8ghz prime95 stable 8hrs (could do more but i stoped test)
just wondering if the temps are ok on load im getting
room temp is @ 25
the max temp on both cores is @ 66
idles @ 35
this is with the cpu @ 1.45v in the bios the nb is @ 1.49v in bios and ram is 2.2v in bios
im using a swiftech 220 ultra water cooling kit
cheers 4 the help
room temp is @ 25
idles @ 35
cheers 4 the help
