Hello
I installed a Thermaltake Water 2.0 Pro Cooler but found the stock fans too noisy , so replaced them with two Akasa apache PWM fans from Overclockers.
They are much quieter but dont run as fast as the stock Thermaltakes so idle temps are around two degrees hotter on each core , not a big deal for the quietness in return !
Anyway i ran Prime95 on "In place large FFT's" for an hour to see how it would do and the system remained quiet and stable ... so all in all do you think these temps are quite ok ? it spiked at 60 degrees just the once ! And know Prime95 pushes the system more than a game or my video work will do .
i7 3770k at stock - no plans to overclock just yet !
Many thanks .
Many thanks .
