- 22 Feb 2010
have my pc on stock cooling, stock voltage stock clock. 2.8ghz
im using an AMD athlon 2 dual core socket AM3
running prime 95 (heat test) these were my temps :
the motherboard i am using is
http://www.overclockers.co.uk/showproduct.php?prodid=MB-377-AS&groupid=701&catid=5&subcat=
with http://www.overclockers.co.uk/showproduct.php?prodid=MY-190-CS&groupid=701&catid=8&subcat=813
ram
i ran prime 95 for about an hour and a half to get the best average temp icould
but something is still burning up? im not quite sure what it is, are the temps okay?
ram
