Hello everybody!
So I'm getting a bit paranoid probably, but after reading loads of forums I couldn't sate my thirst for approval
So I'm running a custom loop of 2x 980 and an i7 devil's canyon. CPU is at stock, don't really need more from it, Cards run at 1500Hz clock and +250Hz on memory (so 500 on final clock).
Cooling wise I have 2x240 rads with the bog standard Corsair SP fans (there is also a pair of 140mm fans pushing the air into the case for a slightly out of whack push/pull on the front of the case since I could fit them
Playing something that would require the cards to swat a little (I game in 1440) I get the cards to 56-57 degrees when fans are on idle (when I forget to ramp them up), turning the fans to ~50% I get back to about 49-51 degrees, water sits on 38-39 at the very most (measured after the 2nd Gpu so at the "hot" point).
Now I know I could use extra 120 rad space, but I did not build the system with enough foresight so.. .yea...
Now tell me if I am being paranoid, or are those higher temps (with gpu's in high 50's) in any way harmful to the system as a whole (pump mainly) or am I good running the fans at idle and all I sacrifice is a few degrees on GPU's with no real draw backs other than my ego
THANKS!
).Playing something that would require the cards to swat a little (I game in 1440) I get the cards to 56-57 degrees when fans are on idle (when I forget to ramp them up), turning the fans to ~50% I get back to about 49-51 degrees, water sits on 38-39 at the very most (measured after the 2nd Gpu so at the "hot" point).
THANKS!
