temps on a 6700k ?
P.B
P.B
2 Apr 2015
im running a 6700k on stock settings which gets me 4.0 ghz at 1.25v and its hitting 70 on load ??
i just tried to clock it to 4.6ghz and 1.35v and was hitting 100
i have a gt110i corsair cooler :confused:
and what thermal paste are you using? You probably need to reseat the cooler.
Mine clocked to 4.8Ghz core, 4.6Ghz cache with 1.34v temp was around 73 during cinebench. Cooler is Megahalems with an EK vardar 2200rpm and Thermal Grizzly Hydronaut.
its a 750d with no front so plenty of airflow and i have quite and aggressive fan profile after 50 degrees and 100 at 70
Sounds like something isn't working, potentially the pump. Or the CPU seating is poor, bad paste contact or just bad paste.
