Hi, I recently finished a htpc build and was wondering if anyone could confirm the temps are ok for this type of chip; here's a snip of HW Monitor.
Im using the GA-A75M-UD2H everything is running fine, the picture above was taken just after I had used prime95 for 30mins or so. The sensor readings are throwing me off somewhat as core temps on idle can drop as low as 7c but when its maxed out its around 52c. Im guesing TMPIN2 is what the bios reads as if I set the temp warning to 60c it alerts when TMPIN2 hits 60c. I ran coretemp and that seems to read TMPIN0 so im running at a nippy 9c on idle i think not
. Its not making much sense so anyhelp from others using this chip would be grateful.
I'm using the scythe shuriken Rev.B for my htpc. It's nice and quiet until you stress it then it sounds like liftoff @ Kennedy. Good to know its not gonna blow heh
