Are these temps OK? I am a little concerned... I have:
Gigabyte 965P - DS3 rev3.3 mobo F10 BIOS
2x1GB Duel Channel Kit GEIL DDR2 800MHz PC6400 Value Ram @ 1.9v for stability (got a blue screen 0x0000000a error, DS3 default is 1.8 so upped by 0.1v as people reccomended).
C2D E4300 @ 1.8 GHz (stock speed and volts) with Arctic Cooling Freezer 7 Pro.
Do the tems look OK here... sore 1 + 2 change between 48 and 51 degrees C. Also, whats with the +12v @ 2.3v ? Is this normal? If not could it be the DS3's BIOS settings?
Please be gentle... this is my first PC build. I have not overclocked anything yet... just set RAM to 1.9v in hope to resolve blue screening)
Thank You
edit: Core temps IDLE are 35 - 37 degrees C. Should this be lower?
Thank You
