Since I built the machine in my sig, I've been baffled by the temperatures I've been seeing. After lapping the CPU and Tuniq, rebuilding into an Eclipse and re-seating at least half a dozen times with different TIMs (now on AS5), I still see idle temps of 45-50 degrees C in TAT and they head over 70 under load. At stock it still hits 65 degrees under load.
Earlier, I was looking at CoreTemp, and I noticed that it was giving my Tjunction as 100 degrees. Now this is the value for Allendales, and is 15 degrees over the Conroe delta point of 85 degrees. After a quick look around the web, I'm not the only person to have noticed this with the L2 stepping C2D chips and it seems that the software may well be misreading them and showing temps 15 degrees above the actual reading.
I grabbed Everest, and it shows my cores idling at 28-33 degrees and hitting 55 degrees under load. This seems far more in line with reports from people with similar setups and also agrees with what I'd expect considering the temps I'm reading on my heatsink with an IR thermometer.
Of course, I could be suffering from a case of wishful thinking, but it seems to make sense. Does anyone have any more information on this?
