I'm currently running my e6600(tuniq tower) at 9x400 with 1.41875 v set in the bios(shows 1.41 in everest and drops to 1.36 when using orthos). My temps are 40-44C idle and 63-64C in small ffts orthos. Are these temps/vcore low enough for long period 24/7 use? I'm going to buy an extra fan for my Antec 900 to blow air to the cpu so I will probably end up 60c in load. Would a zalman fan bracket with 92mm fan help if it blows to the cpu? Where can you actually mount the bracket?
(have to trick it into using 6)
