3000 venice, ok it runs a tad hot cus I'm pumping 1.5v @ 2.6ghz with stock cooler, but it used to do 2.7 at about 35-40 under load.
So why am I hitting 55 degrees at 6000 rpm at IDLE?
Enable-ing "Q fan" has dropped it to 2000rpm and 50degrees?!, I'm lost.
Any advice? Anyway I can get my case airflow better?
ATM i have :
one back sucking air out, one front pulling air in and one side which can suck out or blow in depending on which way i put it. I tried sticking a big house fan next to it but just made temps rise :/
Help?
ATM i have :
Help?
