temps when i have played about
10 Sep 2014
Azaroth
So I have been playing about with my gpus overcloking. I have 2 980s both with a h90 cosair aio cooler on the with the kraken g10.
My 4770k is happy running at 4.5 with a 1.2v oc with a 100h cooler on it. Normally under high loads its hits about 65 ish at the tops. I jumped my gpus to 150 core clock with a +87 voltage and now my cpu is spiking 82 after 10 mins of the division. could the extra 47 + gpu voltage I put on cause that temp rise on my cpu??The gpus hit 55 .
Normally I run the gpus at 120 with a +20 . cpu temp hits 60 tops and the gpus 51.
Well found out wht I had done... somehow I had managed to turn the fan setting in the bios to 200 rpms and qfan was enabled xD. Now my profiles are back on all is good!
