21 Apr 2010 at 22:06 #1 makamiso makamiso Associate Joined 15 Nov 2009 Posts 465 Location Bristol How do i find out the temperature of my componants on windows 7 using the gigabyte EX58A-UD3R? Cheers.
21 Apr 2010 at 22:06 #2 RJC RJC Don Joined 29 May 2005 Posts 29,103 Location Kent HW Monitor & Core Temp or Real Temp. http://www.cpuid.com/hwmonitor.php http://www.techpowerup.com/realtemp/
21 Apr 2010 at 22:21 #3 makamiso makamiso Associate OP Joined 15 Nov 2009 Posts 465 Location Bristol Cheers mate. I assume that the T.J max is something you want to stay clear of right?
21 Apr 2010 at 22:35 #4 Thekwango Thekwango Soldato Joined 5 Feb 2009 Posts 17,405 Location N. Ireland i believe it stands for, Temp Junction Max. something to do with a sensor on your CPU. whatever the max is, when its reached your cpu will throttle back or shut down
22 Apr 2010 at 13:05 #5 Energize Energize Caporegime Joined 12 Mar 2004 Posts 29,960 Location England What matters is the distance from TJ max, the absolute temperatures given are erroneous. Just keep the distance to TJ max above 5 in realtemp.
