- 4 Oct 2005
- Herefordshire
Hi guys I know water is not magic and it will only cool to a certain extent. with this in mind what sort of temps should I expect at idle(just browsing internet ect) and at load, while playing games or funning prime95.
Apologies if the post is long I am going to try and give enough information as possible.
what I am water cooling:
MAXIMUS VI FORMULA
(Via the inbuilt block)
Cpu
Intel I7-4770K
This is At idel overcloked at 4.6GHz with 1.32 volts(this was pre overclocked by Ocuk(motherboard bundle).
Case :
900d
Cooling:
Top of the case
I have a 480 rad(pulling air into the case with the fans underneath the rad(the fans are x4 Noiseblocker NB-eLoop Fan B12-3 - 120mm (1900rpm))
Rear of the case
140 (set as exhaust)Corsair Ar140
Front of the case
X2 120mm (corsair sp120) pulling air in.
On the top drive cage:
120 corsair sp120(red led ed)pulling air in.
Window side:
360 rad(hardwarelabs gtx extream gen 2(x3 Noiseblocker NB-eLoop Fan B12-3 - 120mm (1900rpm)and one Noiseblocker NB-eLoop Fan B12-3 - 120mm (1900rpm) by the side of it so it matches the rad.(Pulling air in , with the fans infront of the rad)
Loop order:
pump/res-out>flow meter-in>flow meter-out>480 rad-in>480 rad-out>motherboard block-in>motherboard block-out>cpu block-in>cpu block-out>pump/res-in.
Now one mistake I think I have made I did not check if there was a direction of flow for the flow meter(instructions hard to read and mostly in german)
model of flow metre :
Aqua Computer Flow Sensor MPS High Flow incl USB Port
http://www.overclockers.co.uk/showproduct.php?prodid=WC-177-AQ&groupid=962&catid=2138
Fan controller
Aqua Computer Aquaero 6 Pro USB Fan Controller
I have set all the fans to 50%(while I learn how to use aqua suite)
Temps/flow
At idle according to auqua suite(flow metre) water temp is 31.6c
flow is 198Ltr.
cpu temp-33c(according to realtemp)
Prime 95(ran at blend)
cpu=67c(according to real temp)
Acording to aqua suite flow meter:31.7
now other temps from aqua suite
480 rad temp =31.6c
360 rad temp=29.9c
ambient temp in computer oom I think is 25-29c
now a few mistakes I have made think I have made.
I have got temp sensors for 360 rad/480 rad, internal temp sensor, external temp sensor. I need to lable these and make sure what is what and label correctly in aquasuite.
I never checked what speed my pump/res combo was set at--idiot I know.
I also never checked if there was a flow direction for my flow sensor.
Anyhow guys does the temps sound normal. I was kinda hoping for better if im honest.
Appologies for the long post, I was trying to give as much detail as I could. as possible.
Please help if you can, or tell me if I have done something wrong.
Many thanks
MAXIMUS VI FORMULA
Cpu
Intel I7-4770K
Case :
900d
Cooling:
Top of the case
Rear of the case
Front of the case
Window side:
Loop order:
Fan controller
Temps/flow
flow is 198Ltr.
480 rad temp =31.6c
360 rad temp=29.9c
Many thanks
