Tempting myself for new build
14 Sep 2011
I currently have:
CPU: i5 2500k @ 3.3GHz
Mobo: Sabertooth P67 R3
GPU: Sapphire HD6950 Flex 2GB GDDR5
PSU: Corsair 650W Modular
RAM: G-Skill 8GB DDR3 1600Mhz CL9
Case: Xigmatek Elysium
SSD: 840 EVO 250GB
Currently getting the temptation for a new build any suggestions?
Currently got this in the basket
YOUR BASKET
1 x EPIC BUNDLE: Intel 4790K, Gigabyte Z97X-Gaming 7, Kingston 16GB 2400MHz Kit and Superflower 750W PSU **£50 SAVING** £566.96
1 x Asus Radeon R9 290X ROG Matrix Platinum 4096MB GDDR5 PCI-Express Graphics Card (MATRIX-R9290X-P-4GD5) £299.99
1 x Corsair Vengeance C70 Midi Tower Gaming Case - GunMetal Black £96.95
1 x Phanteks PH-TC12DX CPU Cooler - Red £38.99
1 x Lamptron FC6 5.25" Bay Fan Controller - Black £29.99
2 x Corsair SP120 Twin Pack Red LED Fans (CO-9050029-WW) £16.99 (£33.98)
Total : £1,083.36 (includes shipping : £13.75 Ex.VAT).
Personally your 2500k is still a good cpu and would wait until the next range of Intels cpu's launch which should be shorty.
Also try overclocking your current cpu.
As above, intels skylake cpu's on the new Z107 platform launch in a few months time to replace Z97. May be worth holding out.
Not kept up with CPU's, but I assume Intel's next CPU will be the Skylake? So about 2 months away?
thanks setter :p
I did originally have it overclocked, but I think my mobo is dodgy as it consistently had issues starting up stating the overclock had failed, hell even now it gives the same issue (forcing me to go into bios/exit bios to be able to start up) and it's on stock :p
Yep, skylake will be the first mainstream Intel setup to make use of ddr4. Expected to be a 30% performance increase over sandybridge.
DDR4 will be expensive on release though, especially 8GB/16GB RAM.
As for monitor, I have 3x 22" BenQ's and don't really have much need to replace them :P
DDR4 has been out for quite a while now. The prices have come down quite a bit since then.
As for 16GB modules then yes they will probably be expensive. For the average user though you will never need a 16GB module. A kit of 4 x 4GB will be enough for most.
I meant 8GB/16GB in general rather than specifically one module :P so as you say 4x4GB kits I'd still imagine would be double that of DDR3 price?
Will have a look now at DDR4 prices
What would you upgrade from the current build?
I play games like GTA, CSGO, etc.
My thoughts right now would be to upgrade the GPU, then when the new intel series comes out get a new case/mobo/cpu/heatsink/ram/psu/etc.
