- 20 Oct 2002
- Surrey
Hi,
Our house was suffering from dead spots in certain rooms so I purchased a budget Tenda mw6 mesh system to try and improve the situation.
Sure enough, there are now no deadspots, but the speeds I'm getting across the various nodes seems poor.
For instance 5m from the primary node, which is plugged straight in to the router and I get 55mbps, whereas I get 70mbps when connected to the issued Vodafone WiFi router. Connect to a satellite node in the bedroom, which has "excellent" connection with the primary node and the speed drops to 35mbps.
Are these the sorts of speeds I should be expecting with such kit, I was led to believe from reviews, this system was good for 200-400mbps, which I figured was loads of headroom on my 70mbps fibre connection.
Many thanks!
Many thanks!
