- 30 May 2007
- Glasgow, Scotland
Hello,
My good lady wife's 2010 Fiesta 1.25 Zetec is having a sad time.
Missfires all over the place, cylinder 4 was 10's per second and the others 3 were basically anytime but not as bad.
Popped leads off and found water everywhere in the spark plug well... lovely, orange and tasting of coolant, bitter as hell.
Spark plugs came out a right mess, one was brittle and ceramic has cracked the other 3 were orange on the ceramic and down the threads... mix of rust and coolant I guess. 3 of 4 also have slightly orange heads, the ceramic before the spark magic happens.
Needed it moving, so put new sparks in today (to move it on the drive!) and its still missing on all 4... although not the 10's per second any more.
Wanted to see if its over heated, and that seems to be the case. Up to temp and no sign of fan coming on, 110oC-ish and the water started boiling and escaping. AC on and off, cant make the fan spin.
Bad times. Needs fan investigated at least, and also probably head gasket or crack in block (?) to be looked at first.
Any thoughts, or am I pretty much there?
Thanks!
Thanks!
