Terminal Question
3 Oct 2006
London
Where does terminal / OS x pick this up from?
It used to display 'JonLaptop' the name of my laptop, but for some reason it doesnt any longer!
Not quite what I wanted but thanks for tutorial on how to use google, I never knew how to use it before! :-)
Maybe I should re-phrase / expand my question a little.... How does OS X decide what goes there automatically? The reason I'm asking is that I'm using synergy and with OS X seemingly changing the terminal name on random I was always having problems connecting to my mac from my pc.
Code:
section: screens
	JonLaptop:
	JONBPC:
		meta = alt
end
That was my initial set up and it all worked fine. Over the past couple of weeks i've had to add this as a result of the different names that appear in the terminal screen. Is this normal? Is there anyway for me to get it to stick to one?
Code:
section: aliases
	JonLaptop:#As set in sharing preference pane
		JonLaptop.lan #As set in sharing preference pane
		JonLaptop.local #As set in sharing preference pane
		Unknown-00-19-e3-37-8b-0c.lan #Macbook mac address
		Unknown-00-19-e3-37-8b-0c #As set in sharing preference pane
		192.168.1.108 #Static IP on my lan
		Jonny #SMB Sharing name
		Jonny.lan #SMB Sharing name
end
Also what's with the .lan and .local bits?
Edit the HOSTNAME= line in /etc/hostconfig
That sets the hostname in stone and should stop you being assigned different ones.
