Hi all
I've got a couple of runs of armoured cable running through the garden and now is the time to terminate them. Below is a rough sketch that shows the current state.
I need to select a consumer unit and/or appropriate housing for (2) on the diagram. This will be mounted to a brick wall and will be exposed to the elements. It will most likely be mounted under a shelf/table, so will need to be secure from children's fingers etc. To cover future use cases (4,5) CU will most likely need to be 4 output. Any recommendations? I've gone through TLC's website etc and the best i've come up with so far is a box within a box, which just feels a bit clunky, but perhaps it's the right way to do it.
Also any recommendations on solving the sockets problem in the greenhouse would be appreciated. Obviously it's a humid/damp environment, so external standard sockets are needed, but also conscious about whether or not it's appropriate to go straight in with armoured into this type of socket.
Thanks
it.
Thanks
it.
