- 19 Dec 2003
- UK
Hey folks,
We have a couple of mains powered smoke alarms in the hallway, since the plasterers skimmed over the artex (and left them dangling) the screws and bracket no longer fit in place as they have plastered over quite a bit of the original area, so I would need to cut back around the plaster etc, try not to cut the artex under it etc etc so I am going to just take them down and replace them with decent branded co/smoke combined alarms, in their place.
The step I wanted to follow was this;
1) Turn off power at fusebox
2) Cut the 4 mains wires from each smoke alarm, take off connector.
3) Terminate the wire ends...
4) Push back into gap inside ceiling
5) Fit new ones in their place
The problem is, terminating the wires, if I use a wire block, it won't fit in the gap to be able to push back into the ceiling, so I was wondering if there is a better way? Perhaps to do each wire individually, but obviously in a safe way...Something that won't be so bulky and will fit to push up the gap.
Is there anything in particular available to buy for something like that?
Thanks
Thanks
