Hi,
Do any of you know if the top and front sections of the terminator case are removable?
I emailed overclockers and they said there was only space for 2 fans in the whole case. I have 3 in atm and definitely space for one more so i think they got the wrong case
. At the top of the case there are grates with 4 holes (1 each corner) that look suspiciously like fan holes- yet there is no way to get to them unless i used super-glue to stick the fans on
At the front there is a 120mm fan which im looking into changing but again there seems no way to get to it without removing pretty much everything from the case - bays and all.
If there is a way to remove top and front sections it would make it much easier.
