hello all, over the course of the next few days/weeks im going to be modding terraria with hd pngs and creating my own texture and loading them in game with terraria png loader and hopefully at the end i will have a complete hd terraria.
cannot wait see u guys soon.
ok so first of all the pngloader which you can download here http://dl.dropbox.com/u/24414601/Terraria/TerrariaPngLoader/TerrariaPngLoader.zip
once you download it you must extract its contents to the main terraria directory which should be C:/windows/programfiles(86x)/steam/steamapps/common/terraria
depending on where you have steam installed
once you have done that you wil need to create a folder inside the custom content folder that you have just installed, name that folder suitable for what images you will be putting in there, for example sprites. then inside that folder create another one called images, this is where you pngs are going to be.
after you have done that, load the pngloader check the tick box's and save and quit then add it to your steam profile
and launch from steam
i will be adding to this with new textures and downloads.
but something like this would be cool to try
