So since I've had my 980Ti I've been having some problems. First was GTAV where it would have low FPS ingame, that was fixed by turning off Vsync (no idea why that worked). Then I started playing ARK Survival and that had some problems with dual monitors anyway unless it was in borderless windowed. Last night I started up Dirt Rally to find that FPS even on menus was stuck at around 20 FPS on fullscreen 1440p. But when I made it windowed it was fine. To fix this I tried a variety of things, but what fixed it was swapping the ports my monitors were connected to on the GPU.
Now today when I loaded up ARK, I'm now having the exact same problem I had with Dirt Rally. 20FPS, and barely 20% GPU usage. But when I click on something on my second screen the FPS in ARK goes back up to 50-70 and GPU usage is back to 99%. Click back on the game again to play and it returns to 20FPS.
Everything in Nvidia Control Panel is stock, I've tried reinstalling drivers and plugging the displays in different combinations. I found one combination which nearly worked, FPS was normal but then I realised G-Sync was not working, and there was no option to turn it on in the control panel. Nothing seems to work properly. It's either fullscreen games work, or borderless window games work. (Or I just don't plug in the second monitor).
I'm running out of ideas, and really hoping that neither the monitor or GPU is faulty.
Things I've tried so far
Swapping ports monitors are connected to on GPU
Changing various settings in NVCP (including VSync, Power Management, Preferred Refresh Rate)
Various ingame settings (sadly not every game has borderless windowed)
Specs just incase
i7 4790K
Gigabyte Z97X-Gaming 7
24GB 2133MHz (2x4GB HyperX Red OcUK, 2x8GB HyperX Savage)
EVGA 980Ti SC+ ACX
EVGA Supernova NEX 650W
Asus PG279Q (Primary monitor)
Dell P2414H (Secondary monitor, in portrait)
Also this is how the monitors show up in NVCP for some reason:
Specs just incase
i7 4790K
EVGA 980Ti SC+ ACX
