If you didn't manage to get any yet.. We (tesco - employee) sell deionised water in the car care section of most super/extra format stores.
Wow, please tell me you didn't sign up just to mention this? If so then I implore Tesco to give this man a raise!![]()
anyway, back to the graphics cards section for more stalking the 7970 posts! (the reason I signed up). Glad you got ya water in the end just a shame is wasn't raising my share value at the same time!I bought asdas entire stock once. 15 bottles. 1.5 litres in each. Big reservoir for my laser cutter.
Quick question. I read something about the irons moving away from the water after an amount of time. True?
Our Asda sells Carplan De-ionised water at £1.50 for 1.5Ltrs. I guess you will only find it in the larger stores though.
irons moving away from the water?
you mean like irons for clothes? or iron bars?
im going to assume that you meant "ions"
well de-ionised water has had the ions taken out which is good because the ions are what change the electrical balance in the water and cause corrosion (from what i remember from my steel structures module)
anyway, if left exposed to air for a long time, the ions do dissolve back into the water which i guess is why they tell us to bleed and clean out the WC system every so often![]()
