Test Socket
18 Oct 2002
Ok i have tried going through my test socket and my connection rockets up about 4 meg, now i thought i could just leave it on there all the time but the telephones dont work if you do, what does thi smean? Do i have to get a new BT box? Is it wired up poorly etc? sky broadband adsl btw
You may have some dodgy extensions, or your face plate may be faulty. Can you elaborate on how you have things set up. If it is the faceplate, then Openreach will probably charge you for replacement as the line will no doubt test fine from the test socket out.
Master socket living room, adsl plugged into that. One other socket in bedroom and a main phone in that with 2 others using it as the base station as its just a 3 pack phone with a main base. I dotn have any extensions so it must be the faceplate, who do i call and how much are we talking about?
