It's test time folks!!!!!!! Answers at the bottom/no cheatin'...
1 If your room's environmental temperature is 23 degrees centigrade, what is it in degrees Kelvin?
a: 147K
b: 233K
c: 296K
2 One minute of arc of latitude at the equator is equal to:
a: 3/5ths of a kilometer
b: 1 statute mile
c: 1 nautical mile
3 An ice cube is placed in a glass of water. What happens to the water level in the glass when the ice cube has melted?
a: It stays the same
b: It rises
c: It falls
4 What is the square root of 49 multiplied by the cubed root of 27?
a: 38
b: 144
c: 21
5 Which of the following is grammatically correct:
a: The cats tail was crooked
b: The cat's tails were crooked
c: The cats' tails were crooked
d: None of the above
e: Answers 2 and 3 are correct
6 DNA is analysed using:
a: Inverse photo-voltaic resonance
b: Reverse codal analytical sampling
c: Electrophoresis
7 The mass of a 1kg cannon ball placed on the moon will be:
a: 6 times it's mass on earth
b: 1/6th of it's mass on earth
c: Ikg
d: none of the above
8 Which of the following is correct:
a: We stayed in seperate acomodation
b: We stayed in separate accomodation
c: We stayed in separate accommodation
9 The SI unit of current is the:
a: Ohm
b: Volt
c: Coulomb
d: Ampere
10 Light travels at:
a: Twice the speed of sound
c: 230 Angstroms/hr
d: 186000 mph
Test over. Check your anwers/count your scores and rate yourself against the barnpot counter, bein' sure to tell everyone what you got, natch'..
- Scores 1-3 = Complete barnpot. 4-6 Should be drivin' taxis. 7-8 Hey - I'm a genius. Scores 9 up - you're a twisted gifted geek that needs to get out more...
Answers: 1c, 2c, 3a, 4c, 5c, 6c, 7c, 8c, 9d, 10d
a: 147K
b: 233K
c: 296K
b: 1 statute mile
c: 1 nautical mile
b: It rises
c: It falls
a: 38
b: 144
c: 21
c: Electrophoresis
c: Ikg
a: Ohm
b: Volt
c: Coulomb
d: Ampere
c: 230 Angstroms/hr
d: 186000 mph
... knew it guvner, honest! And the other one i got wrong was the speed of light...but then I think you should lose a mark for having it as a, c and d
Whoops stand corrected
