Testing a power supply?
7 Mar 2005
I have been experiencing some random freezes in windows which once they've happend I can't get windows to boot from the XP screen or in safe mode. On some occasions removing hardware such as DVD/USB etc will let the PC boot into safe mode and I can do a system restore from which it will boot successfully. Otherwise only a reinstall will fix the problem.
I want to test my PSU, I've read some guides about testing the main power to the board using the 24 pin connector but most boards now have an additional ATX connector. I'd also like to test my PCI-Express connections as I'm running SLI.
Any help would be appreciated as I don't want to have to replace something that isn't broken.
Thanks
Check out the OC website I'm sure they used to sell PSU testers, if I rember they weren't to expensive, othewise try google.
