Testing CPU temps
6 Feb 2009
UK
Hi guys, can you recommend some software that I can run while gaming that will monitor my CPU temps?
Free preferred but may also look at paid software if its a good program.
Thanks.
Afterburner is good cause you can put the CPU temp in an ingame overlay so you can see the temps whilst you are playing rather than having to alt tab to look by which time things might have cooled down.
Afterburner sounds like the app I am looking for. Thanks guys. :)
Can I still run afterburner with my Asus Tweak II OC software?
