- 6 Sep 2008
- Near Hull
is there any program to test memory that you don't need to create a bootable disk for? i just need an executable program that will run in windows xp
For as easy as it is to just whack the memtest86+ iso onto a cd and then let it run, best bet. Would save any potential data corruption or faults occuring due to windows/apps.
Do you mean, is it accurate?
Is MemTest86+ pretty cure to find any memory issues?
Memtest86 is the best bet for a proper and thorough result.
Errors don't necessarily mean faulty, it could be wrong voltage as previously stated, that you're running the timings too tight, the dimm slots on MB could be faulty, nb voltage too low if running 4 dimms etc etc.
Surely this case is a black and white problem with the ram? The only thing that confuses me is that both of the new dimms give faults!? Is that common/unusual?My 2x256mb sticks run fine - no blue screens of death and no errors in memtest86.
My two new 2x512mb sticks do not run fine - blue screens of death and errors reported on both sticks in memtest86 (togethor, and individually, in both mem slots).
I'm running my shuttle system absolutely at stock. No manual config at all... I don't think you even can change the memory voltage!
The memory sticks which I got second hand off the members market are - 2 x Corsair VS512MB400C3 (http://www.corsair.com/products/value_select.aspx)
Just find it odd BOTH are showing faults!
