Testing Memory??
15 Oct 2007
Bedfordshire, UK.
I think my memory is cause me stabliity issues on my OC. I initally stressed my 4.7Ghz OC with half hour on OCCT with max settings and then ADIA64 for 3hrs 40 mins all passed fine at 1.260 vcore. I later noticed that my first video encoding with RipBot caused my system to BSOD, and so have been using RipBot as a stress test, and now need more than 1.310 vcore to try and get the system to be stable with ripbot but its still not enough.
I did a test and basically lowered my vcore back to 1.260 (which it was stable at with ADIA64) also adjusted the memory multiplier form x16 (1600mhz) down to x13 (1333Hmz) and loosened the timings from 8,8,8,24 to 9,9,9,26. I then ran Ripbot and it lasted about 10 minutes before it BSOD. If i had just lowered the vcore down to 1.260 and didnt touch any memory settings then the system would have BSOD as soon as i started RipBot, so i believe its my memory thats the issue.
What can i use to test my memory, i have tried using LinX 0.6.4 but it seem to throw up an error after 3 minutes and gives an error of 'stopped unexpectedly (not enough memory?).' Says Press the log button but i dont see no log button
