What memory you running?
Is that clock prime/LinX stable?
Well thats what i need help with at the mo.
the system is completely stable in games and windows ect ect
but under prime after 2 minutes it will freeze up...
im trying to get it stable. :/ i need to find someone with the same motherboard and cpu so they can help me get stable with voltages.
also i cant seem to find in my bios load line calibration cause my vcore fluctuates quite a bit when going from idle to load ect...
worked a treat.
I find if I overvolt my memory that the system will fail to find it. Try lowering your mem voltage and see if that helps.
Did you try booting up with that one stick installed?
