- 20 Jul 2007
- A sunnier or damper area than Ron-ski....
Hi all,
Just a general question - I've often wanted to test or use PC components (eg pull data from hard disks, fans etc) without having to build it all into a PC case in order to use.
Is there an 'external' power supply option that exists for this?
I've got a pile of old IDE hard disks that I'm wanting to format/wipe properly before throwing away - I've got a usb > IDE/SATA connector so that's fine, I just need to power them via molex.
As PSUs always need a motherboard connection to turn on/off, they're always a bit awkward.
I've done the paperclip trick before to short the PSU and get it working, I'm just curious if there's any proper solutions used for rapid testing etc. I'd be quite happy to have a permanent 'test PSU' that simply has a switch that actually works on its own....
