Testing web applications on a PDA
18 Oct 2002
Derby
I have created a web application in ASP.NET that I hope to run over a network on handheld devices. For testing purposes I have a PDA with no network capabilites at all so basically what I want to do is put my ASP.NET files as well as my MS Access database locally on the PDA. I have been trying to find out if this is possible and which is the best way to do this. I have read on a number of sites there are no ways of installing IIS. Anyone had this problem before or is there a really easy way of doing this task.
Any help appreciated.
Assuming it is a Windows based PDA, why not connect the PDA to a PC using ActiveSync and then access the network on the PDA through ActiveSync?
