change your router security to WEP, simples
no way round that bud. Invest in a router with dual SSID's then you can have WPA on one and WEP on a hidden guest SSID.
Even better![]()
Heh ouchie. Never knew such routers existed! (Or are you pulling my leg?)
Think I may change to WEP one day.
MAC filtering is fairly worthless anyway, from a security standpoint.
Yeah all regular DS games still use WEP. Only exclusive DSi specific gamecards would have WPA security.
As mentioned before, best bet is to just change the security type on your router, or get a USB WiFi stick that plugs into your computer, like the Official Nintendo WiFi one.
How come?
Funny you should mention this. Cause I do have a Nintendo USB WiFi stick.
Is there any risk have two wireless devices so close to each other I wonder?
Also settings wise?
You'll have no problem running the Nintendo Wi-Fi adapter in addition to your wireless network and is a much better solution than having to drop your encryption settings down to WPA on your router.
Windows 7 users: There is no installation software available for Windows 7, and we cannot guarantee that any of the available versions will work with Windows 7.
Ugh well that sucks!
Anyone know of any way to get the WiFi connector working with W7?
