text etc blury in places
Impossible to answer really unless we know what hardware your running.
Blurry text is normally caused by incorrect screen resolution or the monitor refresh rate set to high.
What monitor do you have and what is the refresh rate set to?
It will be your refresh rate if it is a LCD monitor.
My Hyundi monitor is clearest at 60Hz on this rig, yet with my second rig its best at 75Hz (just has lines going across it - think the card is a bit old.... :p)
BLUE|MOON said:
What the title says really, the text on my screen is blury and clear in some places. anyone any ideas please?
Go to device manager and check you have the correct driver Installed for your monitor. ( not the plug and play monitor driver.)
