This is probably really easy but it's been doing my head in for a while and I wonder if any of you guys could shed some light on this or tell me what I am doing wrong.
Basically I have a CSV file of names. This looks like the following
The below code is quite primitive for testing purposes but what I want it to do is:
Read first name of file
Use a SQL statement to insert this name into a table called NAMES
Read second name of file
Insert second name to database
and so on until all names are read and inserted.
Here is my method for doing this:
I gather it is a syntax problem with "output" but for the life of me I can't figure it out. If i try 'output' it literally writes 'output' to the database and anything else I try gives me parameter errors etc..
Any ideas or help really appreciated. I know it's something simple as it always is with me. Thanks for your time.
Code:
Dave Smith
John Smith
Paul Smith
Code:
Sub readText(s As Object, E As Eventargs)
Dim objStreamReader As StreamReader
Dim strInput As String
output = " "
objStreamReader = File.OpenText("C:\Temp\names.csv")
strInput = objStreamReader.ReadLine()
objConn.Open()
While (strInput <> Nothing)
output &= strInput & "<br />"
Dim queryString As String = "INSERT INTO [NAME] ([name]) VALUES (& "output" &)"
objCmd = New OleDbCommand
objCmd.CommandText = queryString
objCmd.Connection = objConn
objCmd.ExecuteNonQuery()
End While
objStreamReader.Close()
objConn.Close()
End Sub
