Morning all,
Before I order some discs and pads from ECP i need to confirm that Textar pads have the rubber backing on the back of the pads? I know that from past experience that fitting pads without the rubber backing can cause brake squeel.
Does anyone know if they do? The other alternative will be Pagid pads but again I don't know if they have the backing too?
Thanks
Thanks
