Hey,
Hoping I can get some help here to find out what's causing this and fix it... This is the exact error that I get: http://imgur.com/dtvKidO
For those that don't want to click the link, it reads "Texture -> Map failed: 0x887 a0005 0x887 a0007. Your video card or driver froze and was reset. Please check for possible hardware/driver issues. This can also occur if you have enabled opencl in x264 custom settings." (I haven't).
The error comes from OBS (Open Broadcaster Software) though after searching around on Google it would seem it's very rarely actually related to OBS, and is more an indicator of a software/hardware issue.
It basically causes a 2-3 second freeze then I get that error pop up generated through OBS and a pop-up at the bottom right with the generic "Display driver stopped responding and has recovered" message
I've had this GPU for about a month now, it was a completely new replacement after my previous one had a fan issue and other than this I've not had any problems. So for about a month now I've been on a fresh install and I'm using the 14.12 driver for this duration.
I'm unable to tell if this happens during certain gameplay or only whilst streaming; what I can say is that for the first three weeks of the month I had no crashes and then for the past week I've been streaming and had this occur twice, may just be coincidence.
Not sure where to start unfortunately
Here's my specs:
Windows 7 64
Intel Core i5-4670K 3.40GHz (Haswell)
Gigabyte Z87-HD3 Intel Z87 (Socket 1150)
Seasonic G series 550w '80 Plus Gold' Modular Power Supply
Kingston HyperX Genesis Grey 8GB (2x4GB) DDR3
MSI R9 280X Gaming Edition OC 3072MB
Thanks in advance
Here's my specs:
Windows 7 64
Thanks in advance
