(Overclockers purchase)
This is really effecting my gaming i have literally tried everything possible from every single bit of advice and no joy on a fix, it's almost like AA or textures i've tried literally EVERYTHING! so hopefully someone has had the same problem here that can shed some light on it
at this point i'm thinking its a broken card.. and it was damn expensive
All hardware is under 3 months old.
Videos in question:
(you can see the hill textures flicker the same on every other game with far away objects it is annoying to say the least, it's almost line somethings moving the textures through each-other (this is usually far away objects) but when flying x-plane or anything else it is incredibly annoying
see here the same thing is happening as in BF and also happens on GTA
and another
Things I've tried
Trying every driver available
Changing aspect ratios
Changing refresh rate via inspector and my screen
Tried changing Response time via monitor
Took the graphics card in and out
Tried every setting in the geforce panel
Taken the card in and out
Tried different cables on monitor
Tried a different slot
Tried another PSU
Full virus check and windows install
So bottom line is what is causing this? something bad from windows or geforce hardware?
Game Ready Driver Version:
419.67 tried removing, without and with different versions no change in safe mode.
Monitor
Dell Alienware 34" Curved UltraWide WQHD G-SYNC IPS Gaming Monitor
Tried every setting in the OSD
Motherboard
ROG MAXIMUS XI HERO
Operating System
Microsoft Windows 10 Home (64-bit) tried different patch releases
Processor
Intel® Core™ i9-9900K CPU @ 3.60GHz (Overclocked to 5ghz) bios is updated, tried with and without overclock
Graphics
GEFORCE RTX 2080 TI ROG STRIX OC tried every setting in the GeForce inspector nothing makes any difference at all
Memory
32 GB 3000 MHZ
Storage
Samsung SSD 860 EVO 500GB
Samsung SSD 960 EVO 1TB
Thanks!
Videos in question:
and another
Things I've tried
Tried another PSU
Monitor
Motherboard
ROG MAXIMUS XI HERO
Operating System
Processor
Graphics
Memory
32 GB 3000 MHZ
Storage
Thanks!
