Texture pop but it's not usual texture issue
5 Dec 2008
Okay so slightly odd issue and it happens so quick I can't capture it in an image.
It's like texture pop in but not to extremes like unreal engine does it, playing battlefront 2 and also recently finished prey 2, occasionally if doing a quick movement around or to side its like the screen will move it but more like a snap effect not smooth.
The texture to side will be there but seem off or washed out, everything in front view will be fine.
I know it's not best description but is this something any one else has had?
Might be rendering bug? Do you mean when textures aren't loaded properly?
Yeah for example in prey couple times I could look up and see outlay for building but no texture or floor that did only happen twice so I assumed just a bug.
I'll try picture it if I can, it's just doesn't appear right
If your texture pops has colours like blue, white, green or other colours mean your GTX 1070 8GB VRAM chips are faulty then you need to RMA it for replacement.
I had textures pops. blue, white and green colours in games on EVGA GTX 670 4GB years ago and EVGA confirmed VRAM was faulty and I RMAed it for replacement and GTX 670 4GB RMA replacement worked perfect without textures pops.
I'll try to capture it when I get on PC again, hopefully gonna be on later this evening. I know my description kinda sucks but I can't explain it really :/
