TF2 - gpld rush = lower fps?
I haven't noticed any problems yet, running smoothly here. Have you got newest updated nforce drivers? The newest nforce driver now would be 175.12.
Q6600@3,6 GHz + 4 GB ram + 8800 Ultra
Yeah it eats my fps as well but I am running at 1920 x 1200 on 24+ player servers. I might try jacking up the the speed of my CPU see it it makes any difference. Although I've only just installed the 175.12 driver so I need to get round to testing them.
Edit: Something bad has happened because I'm only getting 10fps even with everything on low, I bet it's those beta drivers.
Edit: Yep it was.
No problem here with my rig. [email protected] and a 2900XT at 808/900, 4GB 900mhz C4.
I havent checked FPS, normally I'm around 70-80 on other maps. Next time I play I'll check but I don't notice it going any slower then any other map.
I notice it is slightly laggier than other maps although I suspect that is to do with the action always taking place in a single location rather than smaller battle scattered across the map. The new 175.12 beta drivers completely messed up the game though so I rolled back to the December WHQL drivers and it was fine again.
Game runs faster for me with the latest update which is odd eh :p 16xAF 16xFSAA and 1920x1200 resolution !
i run the same as you. same graphics card and same resolution, but only 2.7ghz cpu :)
