TF2 Idea For Medic
9 Dec 2006
@ManCave
here the thread
http://forums.steampowered.com/forums/showthread.php?t=1954658
heres the summary
currently started playing Medic after 3.5 years of playing Tf2
I'm having trouble with selecting the right target to heal when there are a group of two or more. what im suggesting is be able to switch your healing target with an addition button. like Alt or mouse button 5.
so for example i'm healing "Screw" i press alt whilst healing and it switch to the next player near me for example "bine"
now i play with kind of 6 fingers. My right hand is perfectly fine but my left hand i can only use my thumb for wasd & everything else.
so moving around + Switching target can be very hard.
Please add this for us out there.
what do you think of this idea?
I can sympathise with the difficulties you're facing so part of me thinks that it's a good idea. Another part of me kind of thinks that this doesn't really have a place in a PC FPS though. Also, you're using a mouse to aim at targets and if I understand your post correctly you have no problems with your mouse hand so it shouldn't be a huge issue, should it? Are you sure it's not just down to you not really being used to playing as a healer?
if its just for the medigun healing i dont see why it wouldnt be in a pc fps though?
but to answer your question most of the time to heal another target you have to move towards them more etc.
the less i have to with my left hand the better
