TF2 Rates?
As far as I know the game client adjusts the data it sends based on the rates you give it, it's meant to compensate for a slower/problematic connection.
My rates for CS 1.6 were
rate 25000
cl_updaterate 101
cl_cmdrate 101
3 settings
rate 25000
cl_cmdrate 101
cl_updaterate 101
Basically these determine how many times u send commands or stuff updates to the server i guess in simple terms. If your on broadband and not lagging i would use the above settings.
Increasing the rates will improve how your shots register to the server.
You can sometimes lower the 3 settings to lower ping. but it will lower your registering accuracy. Some people lower settings to the point they look laggy on other peoples screen and other ppl register less on them, to cheat i guess.
There ya go. Those are the rates i use for CS and TF2 i dunno if u can go higher but yeah :)
sometimes a quick rocket into the ground and the enmey flies in the air, switch to shotty and a HS will finish most targets. if it registers ^_^
cant u? doesnt it do more dmg?... well u used to be able to in TFC.. thats what i did back then im used to aiming for the head now esp being a cs vet.
