Using an o2 router/bebox/speedtouch/BT Homehub/similar type job?
"# Click on "Start", then select "Run", type "cmd" and press Enter or click "Ok". This will bring up a command prompt.
# Type "telnet speedtouch", or if that doesn't work then type "telnet 192.168.1.254".
# You will be prompted to login to the modem with a username/password. The default is one of the following:
Username: Administrator
Password: None (leave this field blank)
OR:
Username: admin
Password: admin
If neither of those combinations work, please contact your Internet Service Provider for assistance.
# Once you have logged in, you will be presented with the command line of your modem. This is where you must enter the following commands:
* Type connection bindlist and press enter. This will list connection bindings.
* Look for a line that contains "GAME" and some port numbers. For example: GAME(UDP) udp 27010-27011
* Enter the command: connection unbind application=GAME(UDP) port=27***-27*** and press enter. The port numbers in this command must match the numbers that are listed in your GAME port listing, similar to the example above."
