Already have one card installed using both 6pin connecters.
With both cards there is a dual molex to 6pin connecter. Now, i only have one psu cable which is being used to power my bluray and hotswap drive.
Do i need to connect 2x6pin to the second card or just use the molex adapter, which would mean only one 6pin being. As only one comes supplied with the card, am i safe to assume this this is ok.
As you can tell, never used sli/cf before.
