Looking for advice please. I have installed 2 new sticks, set XMP profile which shows 3600mhz 14-15-15-35 1.45V which is the stock setting of the ram. All other settings as auto, PBO is enabled.
In bios (Gigabyte x570i) it only shows as 2400mhz. On Hwinfo64 again showing at 1200 frequency and zen timings confirm 2400mhz. I've tried to manually change in bios but not working. I've checked compatibility on website and all good with mobo. CPU ryzen 5600x.
I had CB memory before and it was showing as XMP 3600 with bios at 3600mhz Hwinfo was 1800mhz. All settings were as above auto, PBO.
Could it be the Tforce is faulty, I've checked the code per stick and referenced on their website which matches my stick's speed and timings.
Any help /advice appreciated.
