TFT callibration in Adobe Gamma
mrk
mrk
Man of Honour
18 Oct 2002
South Coast
Yo, justa quick question, in Adobe Gamma it gives you the option to select the Phosphors:
I have a TFT and was wondering if anyone knew what option to select? with a CRT it was a quick P22-EBU selection but I haven't delved too much into adobe gamma since a display callibration tool started to be put into nvidia display driver and I found that to get nicer results to adobe gammer recently, perhapsI am choosing the wrong phosphors?
What monitor do you have? I f ound that the best thing was no get the profile from the manufacturers website, load that into adobe gamma, and that should set the correct phosphors. Then I just tweak the gamma levels :)
Adobe Gamma errors when I select that profile it seems, it says it found an error and exits - probably because the icm file from the monitors cd is not proper RGB.
I have a 19" hyundai N91w widescreen btw
you really want to use a proper monitor calibrator. I find adobe gamma very hit and miss. repeatability is poor and its not true WYSIWYG when you get prints back from say photobox etc..ie the whole proofing setup.
I have a gretag mcbeth eye one display 2 kit if you want to borrow it...sort out a custom profile for your screen...
You'd let me borrow it? ! If it works out well on this screen then I'll certainly get one too no doubt about that!
Previously when I worked at the studio I used to use their SpyderII but since I don't work there anymore...not so easy ¬_¬
I have had success with nVidias colour callibrator though but of course it's not as good as a proper piece of hardware to do it with
