TFT vs LCD? New monitor in need; tiny stand required.
14 Dec 2008
So I have a nice £400 21" LCD TV, with a VGA input, and a £80 22" LCD monitor which is personally the best screen I have ever owned. However, my computer desk is so shaped that I can't fit the pretty deep TV next to the LCD monitor. So I've begun searching for a new, dirt cheap, 22" (give or take 3") monitor.
What's the difference between TFT and LCD?
Anyone know of any monitors with small stands, that are especially thin?
If you could recommend a monitor I would really appreciate it, but I want it really cheap, good resolution (1680 x 1050), and non-glossy bezel.
I'm aware that OCUK doesn't really do value monitors, and although I'll go to them for almost any other PC part, please feel free to Trust email me about monitors on other sites.
Lots of thanks, and Merry Christmas! :D
*bump* I'm most curious about the TFT vs LCD, so if you have nothing else to add just that would be great! ^_^
TFT just means "thin film transistors. In the case of displays indicates that the controlling electronics controlling the image is embedded on the screen itself.
BTW, high resolution OLED panels use a similar TFT layout to current LCDs, so it looks like the term will stick around for a while.
